Re: Adding 2 way hydraulics to super M
Posted by mkirsch on November 02, 2012 at 07:23:49 from (67.253.161.186):
In Reply to: Adding 2 way hydraulics to super M posted by Fullers Farmalls on November 02, 2012 at 00:43:02:
Pick up a double-acting OPEN CENTER control valve. One with NPT type fittings is easiest to deal with.
Mount the valve in a convenient location.
Run a hose from one of the belly pump pressure ports to the IN on the new valve. Plug the other two ports on the belly pump.
Run a hose from the OUT on the new valve to the belly reservoir fill pipe under the gas tank.
Run hoses from the WORK (sometimes A & B) ports to the rear of the tractor. Add couplers, and you're done!
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
