You mite be turning the engine over a little too much on TDC. I instal them just before the piston is on TDC that way is easier for me. I even most times install just after it would trip done it too many times to remember. Are you sure the rotor is pointed at the tower when it trips cause if it isnt makes installing troublesome.I use the gear that turns them with wts removed and can be driven with a batt drill. Then in a vice with all wires and plugs hooked up i can turn it over and watch the fire at implule and running at higher rpms. Then when i instal i know all wires plugs and firing pattern is good. Another test is having all plugs removed and #1 wire hooked to a grounded plug you can turn the engine over with the starter and having your finger in the hole you can see it fire when on compression stroke thqt way you are sure it will work and you dont install 180 out of time.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
