If the engine gauge is showing oil pressure, it is probably getting oil to the lower end. The oil is routed to the head from the center cam bearing through a drilled hole to the head. The cam bearing has two oil holes in it that align with a drilling in the cam for a moment as the cam turns. This spurt of oil is all that is needed to lube the top end. If the cam bearing is installed correctly, the oil passage might be plugged. a gas welding rod, or straight coat hanger wire could be inserted into the hole from the top while the engine is slowly rotated by hand. If the cam bearing holes are aligned correctly, the wire should eventually drop into the cam passage. (do not keep turning, as the cam will chop off the wire, resulting an a dissassembly to remove the piece!!!) I hope this helps. Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
