The needle might be able to be finessed to work correctly. The float probably has a little dimple of wear in the area that lifts the needle. This dimple is probably pushing on the needle off center from where it was before replacement, and float adjustment. if you can flatten that worn spot from the other side, or put a tiny bit of solder carefully in it then file it off flat it will allow the needle to move concentrically with the flat area and seal well. if the flat area that touches the butt of the needle is not dimpled, it might be non perpendicular to the needle. Any angle there will offset the needle and cause it to leak. Jim
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
