If the governor spring is broke, the engine will race.
If the thrust bearing has bit the big one, the engine won't rev up.
Fix the fuel supply, then time the carburetor to the governor. Engine off, disconnect the throttle rod at the yoke in front. Throttle lever to full. Adjust the length of the throttle rod such that the pin just slips through easily with the carburetor at wide open throttle.
After that, the screw on the bottom of the governor controls surging. Remove the cap, loosen the lock nut, and tighten the screw a little at a time to stop the surging.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
