I believe the axel clamp is supposed to be on the inside notch not the outside. It is not going to raise very high with the front rock shaft control. Since it is a pitman mower the cutter bar can't be raised during operation. The pitman would break if the cutting bar was rotated up toward the vertical position. The mower is to be raised and lowered as a unit using the main lift. The drop rod on the right axel is to allow the mower to raise but limit the depth it will drop when in the lowered position. Looks like you have locked the sway set (pins) way over to the right. That is never correct. To my knowledge you only remove those pins for plowing or cultivating with a colter guided rear cultivator. The pins have to be locked in the vertical position as others have said. Both the front to rear level on the right and the draft level on the left must be in the lock down position not hooked to the front rock shafts.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
