1. Air restriction giving a rich fuel air mixture.
2. Pump/injector problem, feeding too much fuel, making a rich fuel air mixture.
3. Engine problem giving a poor burn. Low compression, bad timing ECT.
So from what you have done so far, check valve clearances seeing as how the cover is off. Then check injector timing by the book. Check and make sure the fuel return line isn't plugged. That can cause the pump to make to much pressure and cause a rich fuel mix problem.
Once al of that is done if you still have a problem it amy be time to pull the pump and injectors and have them tested. Doing a compression test would be in order too.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
