Rub the points with some 320 wet or dry until shiny then see if the engine will start. If you still have a no start and you have a distributor use a volt meter and check for battery voltage on both small terminals with the points open and your ignition switch in the on position. If there's no voltage you need to trace that wire back to your ignition switch and check for voltage at the switch. No voltage at the switch you need to see if there's being fed to the switch. If voltage is fed to your switch your switch is probably defective. Clean the terminals on the switch to make sure there's good contact. Hal
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
