Rod cap bearings. Use a magic marker or blue die and coat the bearing surface. Install them with enough shims removed that they are making contact with the crank journal. Rotate the crank enough for the contact areas to appear in the rod cap. Now you scrap material away from the contacted area and repeat the process until you have a bearing contact area that is close to being about 75% of the total bearing surface. Being a machinist, I made a shaft to fit the bearings onto before putting them in the enigine. I have only done this to one tractor and I still have not got it assembled enough to get it running. Check the archives for more info. SDE
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
