I would first remove the pump & check the oring grooves to be sure you hadn't missed any stubborn remnants of the old orings in the bottom of the grooves.
Take your "new" orings with you to a hydraulic parts & repair shop & see if they can provide you with slightly oversized ( thicker not larger diameter) vitron orings.
Check the flatness of both the pump boss & hydraulic line block with a straight edge. If they are warped take a flat mill b-tard file & GENTLY flatten the surface, the pump housing is aluminum so go easy, a little goes a long way. After removing 10 to 20 thousandths from each this will squeeze the orings a bit more & hopefully stop the slight leak.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
