Dennis, one other thing that can go bad on these is the push rod that actuates the pump. These wear over time (as does the cam) and if there is not enough movement to "work" the pump, that will need attention as well. I don't have the exact amount of travel you should have on the pump rod, but I'll try to look it up.
I am sure someone here has either the correct new rod length, or how much travel it should have. As the rod wears, what you will see is a decrease in the GPM output of the pump. this becomes a problem when the flow falls below the consumtion of the engine. Since these have a by-pass built in, it would take alot of wear to get to that point, but it is something else you can check.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
