If you have the factory pipes with rubber hose the suction is just a short rubber hose with clamps. Pressure hose came made on the smallest diameter steel pipe with a fitting on the other end that screwed on the pump hydraulic manifold. Also you could have rubber added to what came as all steel lines.
If you have the factory lines like in the picture, maybe the easy way is to cut the pipe just behind the rubber. Then get a compression fitting from a hydraulic supply and hydraulic hose with a end to screw on hydraulic manifold and the compression fitting. Second picturing is of the fitting on a gas tractor line so you can see what it looks like. Rubber is 3/4 inch cut to length. Take the old fitting, hydraulic shop will know what ends to use on the new hose.
This post was edited by D Slater at 17:49:38 09/20/12.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
