Let's start with basic laws of electricity. Work performed by an electric motor is measured in Watts x Time (eg. Joules or watt hour). Watts = Volts x Amps. 1 HP = 746 Watts.
If you need 746 Watts for a 1 HP motor at 110V, that is 6.8 Amps. To run that same motor on 220V, that is 3.4 amps per 110V leg. The Ampacity (determined by AWG) of a wire indicates NOT how much Voltage it will carry, but how many Amps it will carry. Watts does not change for DC vs. AC current. The work performed by 100 Amps at 6 volts, will also be performed by 50 Amps at 12 volts. This also assumes a constant Resistance. Resistance also changes in a wire as tempurature changes, so heat is generated by the flow of Amps, not voltage.
So, the bottom line conclusion, using too small an AWG for a 6 volts system produces poor performance, and performance decreases as the wire/cable heats up. A 12Volt system will require less Amps to perform the same amount of work, so hence smaller cables work.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
