Posted by rustyfarmall on September 08, 2012 at 08:26:01 from (67.55.162.174):
In Reply to: farmall h oil pressure posted by jasinpa on September 08, 2012 at 07:59:07:
I speak from experience. My 1950 Farmall H had oil pressure issues. I dropped the pan, removed the oil pump, removed the bottom cover from that pump, and found the gears had worn depressions into that plate. Those depressions were a good 0.125" deep. I also took the spring out and checked it against a known good spring. There was nothing wrong with the spring. As I no longer have access to a milling machine (used to work in a machine shop) I used a large, flat file to restore the cover plate to its original state of flatness (dial indicator was implemented). I put it all back together, filled the pan with 15w-40 oil, and the oil pressure is now excellent. Just to further clarify, I went to SWCC in Creston, Iowa 1970-1971 and took the auto mechanics course. I then worked as a mechanic for a local John Deere dealer, later worked as a mechanic at a local Ford car and truck dealer, and also worked as a mechanic at an independent auto repair shop. In between mechanic jobs, I farmed, held a few other jobs, but always did ALL of my own auto repairs. Enough said.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
