Posted by Owen Aaland on September 07, 2012 at 22:26:06 from (216.47.35.72):
In Reply to: 656 deseil posted by jerry 4 on September 07, 2012 at 22:00:56:
An indirect diesel engine is one that has a combustion camber somewhat separate from the piston and cylinder. The cylinder head and the piston are normally flat or nearly so and the combustion chamber it above the piston with only a small hole leading between the cylinder and this chamber. As the piston comes up on the compression stroke the air is forced into this combustion chamber where the fuel is injected. The burned gases then travel out the passageway to the top of the piston. These engines generally need glow plugs to help warm the chamber or a separate starting motor to crank the engine long enough to warm the combustion area. This type of engine tends to be noisier and a bit more fuel efficient that a direct injection engine.
A direct injection engine will usually have the combustion chamber built into the top of the piston where the fuel is injected directly on top of the piston. The compressed air will be hotter since it doesn't have to travel through a cool passage to get to the combustion chamber. That makes them much easier to start without assistance of an outside heat source.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
