Points ground the coil. When the points are closed, there should be no detectable voltage at the distributor side of the coil from the terminal to ground. When the points are open, with a good condenser, the voltage at the distributor side of the coil should be full battery voltage. The 2 to 3 ohms of resistance through the coil do not drop the voltage on an open circuit (like it is) enough to change the voltage reading on a Multi meter. So basically you cant measure the voltage drop and make sense out of it. In simple terms it is just like measuring from the block to the key with the points closed, and the low internal resistance allows a sensitive meter to read battery voltage right through the unloaded coil when the points are open.
When the points are open the coil should read between 2 and 3 ohms measured across the little terminals Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
