Posted by ericlb on September 03, 2012 at 06:12:46 from (70.41.96.38):
i decided to swap out the manifold on my cub since the exhaust stack refuses to remain attached to the manifold where it joins it, after numerous welding, brazing ect, and i had a good one to put on, it came right off the parts tractor, should have been a 30 minute job, now you know it isnt going to be that easy , and it wasnt, now i got about 1/4 inch of one of the middle studs broke off in the engine of the using cub, right in the middle of mowing season, !@#$, cant even use the manifold flange to keep the drill centered in the hole so since it broke off im figuring a ez out will be about useless as its probably corroded in the block, so what will happen if i use heat around the broken stud on the block to break the corrosion loose? will it hurt the engine, also do these studs go into a water jacket, if i drill thru it? any advise, i really need the cub running today, this all started because it was dying while mowing at part throttle, it had spark,so i blew out the fuel lines, cleaned the sediment bowl, and the cap vent,check for fuel flow, the cub did it again, so i figured i must have trash in the carb, and since i was going to clean it, it was a good time to swap the manifold out too,
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
