Some things to try. Modest compression loss (rings or leaky valves) can be exaggerated at low speeds where there is time for leakage to make a difference. A check of compression on the gas start cycle will check differences between cylinders (they should be within 8 to 10 % of each other) Poor injector pattern at low flow will also produce the issue. Find the missing cylinder/s by cracking loose the injector lines at the pump when running to find the ones not firing. Then swap the injectors between those and running cylinders. If the misfire follows the injector, the injector is in need of rebuild. Pumps and timing can be a factor, but the others are more likely. Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
