Posted by D Slater on August 14, 2012 at 07:53:28 from (184.15.20.202):
In Reply to: Governor on H Farmall posted by Kenneth Blackwelder on August 13, 2012 at 18:06:58:
First place to check is between the governor housing and the front cover. If someone siliconed in place of or on the gasket the oil pressure passage may be pluged. Or if someone made a gasket the slot opening may be left out from front cover plate to the governor housing oil feed hole. Next to check is recent work under the front engine cover or cam bearing recently installed. If none of the above the small metering hole may be pluged from a dirty engine. Oil pressure is not fully sent to the governor housing and idler gear through 360 degrees rotation. Think a slot in the front cam journal just sends oil pressure to the passage so many degrees a revolution. If the cam bearing is installed with holes in the correct place. I may not remember everything about the oil system but the governor is not a complete splash system. Maybe some to the drive gear and front bearing is all.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
