Posted by Janicholson on August 12, 2012 at 10:28:52 from (96.24.99.126):
In Reply to: 350 utility TA posted by RRAJr on August 12, 2012 at 08:22:26:
The Ta has a defective (worn out) one way clutch. This device looks like a roller bearing with ramps for the rollers to wedge into. These ramps allow rotating motion in the direction the engine turns, but prevent turning in the opposite direction. The TA gears are inside a housing controlled by this clutch, and a second regular clutch (though smaller than the engine clutch) When in direct drive TA forward, the gears and housing turn with the engine (the small clutch locks the main clutch shaft to the TA case making it turn 1:1 with the engine. When the TA lever is pulled back, The little clutch is released. This allows the TA gears (planetary gears like in a auto trans) to operate. this makes the TA gear case try to turn backwards. The one way clutch prevents this from happening and reduction happens. Unless!!! that one way clutch fails. Then the TA case rotates backwards and the tractor doesn't pull, either at all, or only weekly. So the repair requires the splitting of the tractor at the TA housing to Transmission, and at the bell housing. Not a terrible task with good blocking, and a cherry picker. The support of the engine and front end is important. TAs are better than sliced bread. The tractor is workable as is, but deserves a TA. (I own a 350U and it has the original TA and was used hard. Moving the stick like it was a toggle switch, snapping rapidly in either direction is the key to long life. slow lever movement slips the ta clutch. Do not let TA adversaries give you the wrong impression. The repair will cost modestly if only the one way clutch is replaced. If both clutches are replaced, 2 to 300 is probable, if a rebuilt TA is put in they are in the 550 to 650 category. Jim
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
