Posted by The tractor vet on August 08, 2012 at 08:55:34 from (76.212.234.198):
In Reply to: 3688 TA pressure posted by dwag on August 07, 2012 at 16:17:11:
When you replaced the spring did you check spring lenght ?? Did you replace the MCV pump ?? are you sure that you do not have a leak and loosen pressure else were . Normally i have to remove a coil or two to decrease pressure to get what i want . Normally with a new spring kit you would be at around 290-310 and depending on what tractor it is i set pressures between 235-275.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
