Posted by rhtx55 on August 05, 2012 at 14:10:16 from (207.119.62.8):
In Reply to: 300 row crop 6v or 8v posted by swagger d on August 05, 2012 at 04:36:20:
AS noted previously, all F300 Row Crops came factory with a 6 volt positive ground electrical system. Some may have been converted over to twelve volt positive ground after the 350's 450's came out, and dealers offered this conversion.
The amp needle jumping is caused by the voltage regulator "buzzing",
I would clean the all wire connections at the genny & voltage regulator shiny bright & coat with di-electric grease before re-assembly,
If the needle is stilll "jumping" the regulator is still " buzzing" and needs adjustment, remove the regulator cover, file & clean all contact points, then re-set the air gaps:
Your regulator is different than the ones shown but the contact cleaning & adjustment procdure is the same.
I have an F300 rowcrop & have tried the 8 volt battery. Yes it starts quicker, but you tend to blow light bulbs a little quicker , and fry a lot of points. The trick I have found is bring the wiring harness up to 10 ga wire & above, clean every contact point to bright & shiny, coat with di-electric grease to keep them from re-corroding, (double ought) 00 battery cables with the ends soldered, rebuilt genny, rebuilt starter ( brushes, bearings,bushings, starter drive) adjusted the fan belts, and tuned to where it will start after two or three revolutions. This was a carb & distributor rebuild ( carb kit & pivot weight pins, springs retainers, shaft bushings, echlin brand points, condenser, rotor, new IH distributor cap.
This worked very well until the coil went bad, would get so hot during a parade that you could not lay your hand on it, replaced the coil & life is good again, purrs like a kitten. Don't get me wrong, it took almost two years to get all this accomplished, do what you can when you can, and be wary of some aftermarket replacement parts such as points, you get what you pay for, I went through six aftermarket sets of points & condenser, I found the echlin brand & they are made much better, almost twice the price, but this set has lasted me two years now with no issues ( well as of today anyway).
1. check & adjust fan belt tension
2. clean any & all wire connections to shiny bright
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
