If I simply take the wire from the GEN terminal on the regulator, and move it over to the BAT terminal on the regulator, will that effectively bypass the regulator?
YES that by passes the Cutout Relay portion of the Voltage Regulator (its between BAT and GEN). If you do that the hot ungrounded battery feed via the ammeter which is present on the BAT terminal, is then connected to whatever you then connect that terminal to, such as say the output of an alternator...........
DONT FORGET MOST ALTERNATORS ARE FOR NEG GROUND so if the tractor were at Pos Ground??? you would have to swap ammeter leads or it will register bass ackwards
If a tractor has a coil ignition and you changed polarity, the coil leads would also need swapped HOWEVER if youre already at neg ground (like on most 12 volt tractors) neither of the above swaps are necessary
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
