I would try cleaning the connections at the ignition switch & solenoid on top of the starter, after making sure the battery cable ends are shiny bright also. Any corrosion robs a 6 volt system of much needed amperage. High quality copper battery cables double ought in size usually help a lot, a welder friend of mine offered me some of his discarded cable he had lying around & it works great. I soldered new terminal ends on them both.
The larger cables offer less resistance. Any wire you need to replace, go with 10 ga copper, less problems down the road.
I would go with the highest cranking amp 6 volt you can find, the heavier the battery the better, this means the lead plates inside are either bigger, or there is more of them.
The best ( and most expensive) I have found, BUT at least you never have to worry about rust in the battery box again :
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
