You should show only about 200 psi above what the regulated pressure is when you are not turning the steering wheel. That would be the differential pressure behind the flow divider valve added to the pressure of the regulated circuit. The reading you are getting down on the bottom plug is regulated pressure and should remain close to the same at all speeds. Sounds like you have a restriction but your steer to stop pressure sounds good. Steer to stop is controlled by power steering relief valve, regulated pressure is controlled by regulating valve and is the return oil from power steering so the steering pressure will always have to read regulated pressure plus the differential pressure build up behind flow divider.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
