It could be that the splines are worn that engage for 5th gear or it could be that the detent ball is missing or the spring is broken, which would be much cheaper fixes. You may want to start by dropping the belly pump and removing the input shaft, U joint and upper constant mesh gear assembly. This would give you a chance to look at the gears that make 5th and see what kind of shape they are in. The top cover is not too bad of a job, just remove the belt pulley drive if so equipped, the gas tank, the seat, unbolt the steering column from the top cover and hoist the whole thing up a bit in the air if you don't want to have to disconnect everything. The top cover is not that heavy, maybe 100 pounds at a guess. If it sticks try tapping in hardwood wedges in the crack between the rear casting and the cover, try not to whack the "ears" of the top cover too much with a hammer as they will break off pretty easily. Zach
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
