Re: Super C hydraulic line
Posted by NoNewParts on July 13, 2012 at 06:23:26 from (67.240.145.25):
In Reply to: Super C hydraulic line posted by Charllie in MO on July 12, 2012 at 19:17:59:
like said, since you have a SC, best option
is the factory lines, valve setup from a fast hitch
the bypass block is also a good option
saw one setup on ebay where the pressure line
was cut and sent to a remote valve, then back to the
line to go into the factory setup
on one of my SC's which needed a total rebuild on the
touch control factory hydraulics...
(stuck valves, pump deadheading always, factory remote valve was also junk)
I didn't need them, so I got regular C lines, and made a block off plate
with just the suction line hole drilled out.
removed the plug from the pressure side of the flange.
routed it thru an open center valve, with the valve return plumbed to
the touch control drain.
So, the touch control is just a reservoir.
works fine to run my fast hitch
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
