Posted by JRSutton on July 10, 2012 at 09:18:44 from (75.130.109.233):
In Reply to: Y69 will not start. posted by grizzlyclaus on July 09, 2012 at 14:57:37:
Many people get confused with TDC - remember there's a top at the exhaust stroke, and a top on the compression stroke.
So you want it to fire on the compression stroke (or immediately at the end of the compression stroke).
It's good to have it fire a degree or two after tdc - to avoid kick back, especially hand cranking. Once started, the mag goes into run mode and advances itself.
Go any further than about 5 degrees past tdc and it's going to get increasingly harder to start. You really want to be just very slightly after.
Also - just because you're getting a spark doesn't mean you're getting a good spark. If the arm in the mag is off a few degrees, you'll see a spark, it just won't be very strong. Hold a plug wire near ground - make sure it's at least 1/4" solid blue arc.
If all that checks out - try a little starting fluid. If it fires on that - you'll know you should probably focus more on the carb.
I'd also pull each plug and make sure that each one is sparking - never assume.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
