First with the engine off take the pin out of the clevis going to the carb.Now open the throttle then see if holding the rod going to the carb open the pin will go back in if not then adjust the clevis.If that doesent solve the problem the gov should be removed and the bearing on the shaft mite need to be replaced. The bearing has three pieces a washer on each side of the bearing. Then theres a spring that mite be broke. that then should solve your problem if not remove the carb to see if the input lever has slipped loose getting the butterfly all out of whack.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
