Posted by pete 23 on June 24, 2012 at 19:28:27 from (74.32.238.2):
In Reply to: SH hydraulic question posted by oregonfarmer on June 24, 2012 at 06:46:56:
Try the other outlet. If you look at the parts diagram of the Super H hydraulic lift all, regardless of which one you have with belly pump or live pump, you will notice two different styles of check valves holding the load up. The one they call a differential check valve has a much smaller ball and therefore when holding heavy loads it is much easier and smoother too release to lower the load. If you are using two hoses, one on each side of what ever your are holding, you will have to T the two together to use the single outlet. I have over the years installed that style check valve to overcome just that problem you are having. If your H should happen to not have that small ball set up you can install it but you have to make sure the pin operating the ball is correct length so as to hold the load up when lever is in neutral position.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
