Posted by pete 23 on June 20, 2012 at 19:50:39 from (74.32.238.2):
In Reply to: 656 hydro exploratory posted by ChShaffer on June 20, 2012 at 19:21:35:
Question, is the main suction tube loose (38 in parts illustration)or is it the pipe the hose hooks onto that has come loose from the main suction tube. I am trying to remember how pipe fastens to tube as I have it in my head that the hydrostatic tractors used a larger aluminum suction tube than the steel tube used in gear drives which pipe was welded to tube. If main tube is loose you may be in big trouble as I have had to split them to repair on gear drives when bracket broke off where it is bolted on. If main suction tube is tight you might be able to just leave the return hose off entirely as long as main tube is well below oil level. I have seen guys do this when some loads like loaders drop so fast it keeps blowing the hose off or bursting it. The reason for the hose and pipe is because the pumps deliver more gal per min than the capacity of the reservoir so it depends on what you are using if it will get you by or not.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
