As i was setting on the pourch i got to thinking on how i made them brackets for the 06's . Like i said i used a couple pieces of 8 inch channel iron and cut the one lip off leaving the one to the rear, then i cut four pieces of angle iron to conform to the angles on the axle housing and the u/ bolt that i had made conformed to the angles of the axle and each side used two U/ Bolts. Then ya make up the tabs that ya bolt the sub frame to with the two 1/2 inch bolts . Ya remove the three point hitch arm if it is three point and if it is a fast hitch ya have to remove the lower fast hitch bundle .Ya install your drive sprocket and adjust the driven sprockets to line up and install the drive chains , then ya back into the husking bed and hook it up and once that is done then ya drive into the gathering unit flip the clamps down over the axle brackets hook up the lift cylinders and and the drive shafts and go to the field.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
