Thank you. I have ordered a kit with all of the parts you mentioned. At this point the tractor is not wired, I have a battery sitting on the floor with jumper cables to connect it to the tractor. I had the - cable to the frame rail and the + cable to the resistor with the other end of the resistor connected to the coil. I am not sure if that is proper or not based on what you said. I am turning the engine with the hand crank. The whole tractor needs to be rewired but if I need to split it I'd rather do that first. I don't need to be able to move the tractor right now, I'm just hoping to get it running so I can find the squeal that the PO described and also see if the hydraulics and IPTO work. I did drain the oil and look at the seasonal disconnect, which seems to be in fine shape so I guess that is not the problem. Zach
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
