And while we're at it - if you DO decide to go with the kit (which can help clean up slop in the steering) Most of the stuff is pretty straight forward - really only one way it can come out and go in.
However, the old brass bushings can be REAL tough to remove. The best way I found to get them out was to take a hacksaw blade - insert it through the hole and cut the bushing lengthwise all the way through - you can nick the cast iron without causing a problem, but obviously keep it to a minimum.
It's best to make two opposing cuts - then the remaining bushing halves will knock right out with a chisel.
Your oil seal on the top of the steering box where the steering shaft goes through is probably a double thickness leather seal. The new one will be half the thickness, don't let it concern you - try to seat it flush with the top of the hole - you'll see what I mean when you get it.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
