jimb2 said: (quoted from post at 19:27:37 06/15/12) Hi South_MS, I reviewed your photos again looking
at the injection pump and I think someone has
backed out the power screw on your injection pump
to the max so engine is probably being over
fueled.
The power screw is the front screw that the
STOP/START/RUN lever limits against. If your
STOP/START/RUN lever is working properly, don't
pull the lever all the way to the top of the slot
and the lever on the side of the pump will no
longer be limiting on the bottom front power
screw. That should make the D-179 run a little
leaner and clean up some smoke but you need to
give it a good hard workout.
JimB
Folks,
Thank you so much for taking time and suggest a ways to get it going.
Today I found online that injectors need to have a return line hole pointed toward the valve cover. Mine were pointed toward outside. So I took the #1 injector out and found that it was covered by slimy black mud- looking residue, the entire injector assembly when I pulled it out looked like it was found in a mud and stuck in there. I cleaned it out, then reached in the injector seat with clean rag and wiped all the grime out. The injector body looked like it was subjected to the rust. Since I have no idea of the past of this tractor it is safe to suspect that injectors were messed with . The guy who gave the tractr to me told me that he had injectors rebuilt by some 'friend' of his.
Anyways I cleaned up injectors . Unfortunately I couldnt make a snapshot because didnt want make my camera all greasy and smelling like fuel. Cleaned injectors, put them back on with return line pointed toward valve cover. I didn't think it would make any sense but still, I asembled everything the way it was. Spun tractor over and it fired right up. I loosened up injector nuts some to bleed the air out and tightened everything up. Once engine warmed up I noticed much much less smoke compared to what it was. It still smokes some but I am guessing as some of you suggested once I give it a good workout it should clear up some.
I think I will need to start looking for a replacement injector asemblies to replace my eaten up ones.
I also wanted to run something by you experts out there.. Someone told me today that I should add some transmission fluid to the diesel fuel because he said nowdays the ultra low sulphur fuel that I get from the pump don't have any lubricant in it. Is it sound right ? I am skeptical about that statement. What's your thought?
This post was edited by south_ms at 20:02:54 06/15/12.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
