The 66 series uses a closed center brake valve unlike the 06 series that used open. In other word, when you use the brake you are using oil from regulated circuit, so if you did not have an orfice in the brake inlet that might be the problem. Other wise, a leaking sump check valve could be problem. As long as steering works good I think we can forget about pump, flow divider and flow control valve orfice. It all comes back to pressure testing and comparing results in all positions. Remember, when checking regulated pressure, the middle position should drop 20 psi which tells you regulator valve is moving freely as there is no flow to ta in that position. You can often pin point a problem area with gauges but sometimes it just tells you things are working properly or not as you more than likely know already.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
