Posted by Zachary Hoyt on June 06, 2012 at 18:28:12 from (173.84.185.1):
In Reply to: H pilot bearing ? posted by riverbend on June 06, 2012 at 14:48:35:
Reading your question again I see I have said it wrong. You can remove the belly pump and then the U joint, then the input shaft, then the whole front transmission bearing/constant mesh gear assembly slides out the front. Then you can unscrew the bolt from the tip of the transmission upper shaft, pop the pilot bearing off and pop the new one on and reassemble. Usually the bearing is an easy slide off and on, I did have one that was stuck once and I had to tap it off with large punch. If you need to get at the pilot bearing area once the constant mesh gear is removed you can remove 6 bolts and pull the belt pulley housing, which will give you another angle. Zach
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
