There are only two screens, one of course is the by pass valve between the two filters whose purpose is to open if hyd filter is plugged or when oil is too thick to pass through the filters. If you have the original style with a thermostatic pellet on it I would throw that away and get the later one with just a spring loaded valve. The only other screen that would effect your lube light would effect a lot more. Later in production of those tractors, a screen was added between power steering pump and relief valve, right in the fitting on end of hose going into valve . This was to prevent complete contamination of entire system if power steering pump fails internally. I have been there, done that on a couple. I would not be immediately concerned if the light will stay out at a moderate speed, say maybe 1200 rpm or so. Then when you get a chance have someone do a complete pressure test on the mcv, checking regulated and lube pressures according to the book. Also, don't idle that tractor down to low idle except for a few seconds. There should be a decal on the windshield or console warning of this. Tears the shock absorbing drive unit up at the flywheel end. The fluid flow from power steering pump , steers first then goes to flow divoder in MCV and operates the rest of tractor controls, like TA and brakes then it lubes parts of trans.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
