The hydraulic reservoir for the 240 is not located in the rear end. I am not sure but I believe it was mounted under the gas tank much like the SC. Trace out the oil tubes from the hydraulic pump located in front of the distributor. They should lead you to the reservoir. Otherwise, check your operator's manual. Do not overfill the transmission/rear end. If you have done so you need to remove the oil down to the check point. It should be a threaded plug on the rear right side below the belt pulley or belt pulley delete plate. These units were not designed to use hi-tran fluid but they will work with it, just slower. They were designed for an oil very similar to 30 weight.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
