Posted by Jim Becker on May 25, 2012 at 16:21:41 from (173.74.120.222):
In Reply to: No start A Farmall posted by SDE on May 24, 2012 at 15:37:50:
There is nothing wrong with what you said. The entire portion of the magneto behind the points is called a distributor. The cap with all the secondary wires stuck in it is a distributor cap.
The spark at the plugs should be about as good as the spark at the coil. You appear to have a problem with the cap, rotor or the wires. Make sure you have solid core wires, not resistor wires. I'm not saying this is the cause of your current starting/running problem, but you do want to look into it either now or later.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
