Re: Farmall 300 oil pressure
Posted by NoNewParts on May 14, 2012 at 05:41:50 from (67.240.145.237):
In Reply to: Farmall 300 oil pressure posted by Mark J in Mi. on May 12, 2012 at 08:45:40:
bearings getting worn
10w-30 is a little thin for worn bearings.
15W-40 diesel rated oil will pick it up some if worn.
Put rod and main bearings on your future to do list.
not hard, and you can put a new oil pump cover gasket and
relief spring(if applicable on that motor), and plane the cover
when you are in there.
with that said, I've had tractors that dropped worse. no problems, I
just knew that I would have to roll in new shells when I had the time.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
