Don't know about the stuff rear of the clutch on that model,
but the engine looks like an easy one.
Like said, the rusty plug cylinder is where a problem is.
make sure the valves are not stuck.
if some are, pull the rocker shaft to take that out of the equation.
blow out that cylinder or reduce a shopvac hose until you
can get it in the sparkplug hole.
You have to get any water out first or your solvent
will just float and won't do anything.
Then soak em all for a few days with your favorite solvent.
You can then pry on the flywheel gear, or in a normal situation
rock it in high gear (sounds like not an option for you)
I don't have much luck with that, I put a oak stud on my floorjack
and gently put some upward pressure on a rodcap/crank throw.
usually works
smaller, lighter tractors with very stuck engines, I jack the throw until
the front wheel is light. When I come into the shop
and the wheel is on the ground, it's loose.
at the first sign of movement, switch from solvent to lots of oil
before turning it over
good luck
EDIT: just had to add after seeing eltoro's same time post, that when all else fails, fire works. very stuck 123 that I just freed resisted everything until I set it on fire :D After burning, jack on a throw going up, pounding on a piston that was going down freed it
This post was edited by NoNewParts at 04:27:36 05/14/12.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
