Posted by SuperABen on May 06, 2012 at 10:25:11 from (64.203.149.227):
My A has not run in nearly three months. There's a long story there as to why a Farmall tractor lover can't find time to go out and start his A, and part of that includes the reason why I have not taken time to rectify the original problem!
It was originally parked to repair some faulty wiring. The previous owner replaced the generator (6v with relay) to a newer version, still 6v, with a 3 terminal regulator. Somewhere along the way the wiring had been replaced to modify a relay system to a 3 terminal regulator system.
I restored the tractor about a year ago. The engine on this A is perfect mechanically, so I did not perform a rebuild, only a paint job.
~New (previous owner) 6v generator, remake ~New (previous owner) 3 terminal regulator ~Original 4 position light switch ~Original H-4 Magneto ~New (previous owner) wiring to match regulator
After a few months, I noticed the generator was not charging. In the process, I noticed that someone had stacked the "L" load wire on the regulator onto the "Bat" terminal. This was fixed, but when I tested the generator again (engine running) I found that it had no charge. I assume the wiring either burned the regulator or the relay; I have not confirmed that exactly yet.
The next day I went to start the tractor to try another test, but the battery was discharged down to 4 volts. I do have a 12 volt jump start which I have used in the past, so I tried that. Surprisingly, the starter only engaged the flywheel slightly then stopped. I had an extra starter, but it also did, and does, the same thing when hooked up to the tractor. Normally, my 12v jump start will easily spin the engine; it still works fine for my Super A, which incidentally needs more amps to spin than the A.
I have also bypassed the starter switch by jumping to the starter case and the copper terminal, with the same results. Lately, I have tried my 12v jump start straight to the starter, with the generator and 6v completely disconnected, and I still get the same problem.
Obviously, something has gone awry to discharge my battery to 4v overnight, as well as keep my 12v from easily spinning both starters. I also think it is not a starter issue, since both starters have the same problem on this tractor. I hooked up my multimeter and noticed that the jump start discharges down to .5 volts when trying the starter. This may be normal for a 6v, but I would think a 12v would not discharge so low... but I also don't claim to be a electrician!
The only other thing which might cause trouble is a wire I hooked up to ground the kill switch; the switch used to ground itself through me when I shut off the tractor! I attached one end to the knob and one end to the tractor frame. Could this cause trouble, even though I have had this attached for a year with no problem?
Has anyone seen a starter issue like this before? I admit to being stumped! My current solution is coming this week-- a hand crank!
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
