Dirty field control points in the regulator can cause the problem you are having. Cleaning them as Jim suggested will probably correct your problem.
Dirty contact points will cause a higher resistance between them. When the generator is first started up the voltage in the field windings will be very low, possibly less than one volt. You need good contacts to ensure that this low voltage is grounded. With a good ground the field coils will use the small amount of current generated to become electromagnets to add to the residual magnetism in the pole shoes. When that happens the voltage will quickly spike upwards until it is great enough for the regulator to start to control the maximum voltage.
The simple test is to ground the filed terminal on the generator once the engine is started. If that causes the generator to immediately start to work you know the problem will be dirty or loose contacts.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
