Posted by Yooper Farmall on April 30, 2012 at 07:36:28 from (141.210.112.16):
The upper plow assembly connects to the lower moldboard assembly via two steel plates sandwiched together
The wrench is on one of two 5/8” bolts that connect the upper assembly to the sandwiched steel plates.
The two empty bolt holes on the bottom of the plates takes one ¾” bolt (front) and one 5/16” bolt (back)
The 5/8" bolts are pretty good sized, but it struck me that the lower bolts were a larger 3/4" bolt paired with a much smaller 5/16" bolt.
Could it be that the 5/16” is meant to sheerer if you hit a big rock, making the whole arm pivot on the ¾” bolt and flip the moldboard back?
I've heard of break-away hitches on pull behind plows.
I believe all the bolts on the plow were grade 2, I replaced them all with grade 8. If this 5/16" bolt is meant to sheerer I'll have to replace it with a grade 2.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
