Posted by Janicholson on April 28, 2012 at 15:47:22 from (96.24.99.126):
In Reply to: surging A posted by charlie M on April 28, 2012 at 13:08:47:
Be sure that when the governor is set to wide open(tractor off) that the linkage from the governor cross tube arm and the carb link arm, The carb should be held just fully open in this position. The pivots and rod ends should be tight and without slop. They can be welded up and made tight. The tube from the governor can also have bad bushings in the end, If these are OK, and it still surges, there is a possible issue with the high speed mixture (helped if the float level is correct). The main bearing in the governor.can also be loose. Jim
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
