It's a relatively straight-forward job. A few tips from my experience:
- An engine hoist, or a tractor with a front loader will make the rest of the job MUCH easier/safer.
- Jack the front end then support the tractor with timber cribbing or similar beneath the clutch housing so the front wheels are off the ground. Be sure to block the rear wheels both front and back, and set the brakes!
- Remove the lower bolster/wheel assembly. Note one of the 4 bolts (the right front) has an extended head. It sets the left/right steering stop. When reinstalling the front wheels this bolt must replaced in the same location with the pivot shaft in the "straight ahead" position.
- The pivot shaft gear is on a tapered spline. To remove take out the cotter pin then loosen the nut on top of the gear 2-3 turns. A few good licks from a large hammer/sledge should pop the gear and let the pivot shaft drop. Protect the nut with a scrap of soft metal while hammering. And remember the pivot shaft is HEAVY - watch your toes!
- The old bushings are best removed by splitting with a cold chisel then collapsing so they can be pulled out.
- New bushings should go in easily with a bit of light tapping. Be sure to align the lube hole in the lower bushing with the grease fitting on the fixed bolster. Or remove the grease fitting and drill through the bushing wall after it's in place.
- The shaft seal can be a stinker to install. I turned a "tool" from a wood dowel scrap to position and knock the seal into place.
- Even with a new seal the steering box is likely to have a slow oil leak on account of shaft wear in the seal area. Better idea is to pack the box solid with good quality grease - it'll lube the worm gears just fine and it won't leak past the seal.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
