Posted by Janicholson on April 24, 2012 at 18:00:23 from (67.72.98.45):
In Reply to: SH Oil pump Gasket posted by VA Gasman on April 24, 2012 at 17:34:45:
The gasket is a shim and gasket as one. THey come in differing thicknesses. CaseIH should still have them. 100% rag content paper will work. Grease the paper before use, and it will be OK. The rotor to cover clearance is tight, .001 max to .0005" Flat sand the cover to assure it is flat with 320 grit Silicon carbide on a piece of flat glass. Thickness can be measured by carefully tightening the pump on a small tab of .001 shim stock. as it is tightened down gently, the gear will seize when moved back and forth a little if it is tighter than .001. If looser, it will not lock up, and the gasket shim is too thick. if it does lock up, a .0005 shim should lock it up. Do not over tighten it with the brass shim stock in it or you will warp the cover. Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
