Posted by FC Andy on April 20, 2012 at 15:23:34 from (74.126.84.52):
Little story for ya:
Yesterday's project was adjust the clutch on the 806. None of the neighbors are needing my help farming, and I couldn't just sit around.
So, I looked up one of your old posts on how to adjust the clutch, TA dump valve, and transmission brake. Also consulted owner's manual for clutch free travel, and away I go. Well, all the linkages were frozen up. Figures. The threads for the adjustment of the trans. brake actually galled up and I will need to fix that before I leave work tonight. The clevis end, thankfully, cleaned up just fine after running a tap through it.
So, after cleaning up the clutch and TA dump linkage, I put them on this morning. Adjusted them to approx 7/8" free travel like book says, and set TA dump to just turn light on at full travel (pedal floor tab hitting floor) like you said previously to do. Now, I apparantly learned why those transmissions have a brake on them. I tried to shift it, and the transmission simply did not stop spinning. I did not press the issue, or shut it down and then put it in gear, because I simply did not need it today. I'll hopefully get it all squared away tomorrow morning.
Which leads me to my questions: is that normal for the transmission to "freewheel" like that? I assume so, hence the trans. brake. Older tractors don't do that, although, they don't have a brake, either. Second: Is it possible to get the trans. brake too tight? Before I started this project, I often actually had to partially let out on clutch pedal to shift gears. Couldn't do it at full extension of pedal. If that happens again to me, should I then adjust linkage so that transmission dosen't stop spinning, and then pick the mid point? Just wondering, I know that you and Owen and Pete know far more about the subjects I ask questions about. Thanks! -Andy
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
