Posted by Super-H-Mike on April 20, 2012 at 07:41:33 from (76.164.145.223):
In Reply to: 1586 hot posted by jim mall on April 20, 2012 at 04:51:54:
If it is trapped air in the system, I can tell you what I do on automotive engines...I fill it almost full, then run the engine till it just starts to get "hot", then shut it down and wait about 3-5 minutes and repeat the cycle over again. By stopping the engine, the heat has a chance to transfer around and equalise somewhat and gives the stat a chance to heat up and open. . The air will usually work itself out in the process. Can take up to 4-5 cycles on stubborn ones. After it is circulating, top it off and cap it. I also use the special air operated vacuum devices to purge systems , but this cycle method works too. Good luck to you !
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
